November 12, 2007, 19:18 |
UDF for changing angular speed
I need to make unsteady calculations of rotor-stator interaction. Angular speed is increasing. I'm using sliding mesh to specify the rotor motion.
How rotor speed increasing can be specified? Suppose I should use UDF but can not find proper one. Please write how I can solve this problem? Thank tou |
November 12, 2007, 21:02 |
Re: UDF for changing angular speed
Dear Ilia,
I am sorry I cannot help you with this. However, if you find how to change the angular speed as a function of time be careful what kind of accuracy you want from your model. Why? 1 - FLUENT implementation is for constant angular speed. It is missing the source term in the momentum equation that account for the angular acceleration (omega dot x R). 2 - If your simulation requires the solution of the energy equation, you also need additional source terms not provided by FLUENT to account for variable angular speed. Good luck, Opaque |
UDF to change Rotation Speed in a MRF simulation | Mike | FLUENT | 3 | September 27, 2011 06:46 |
UDF For Angular velocity for gear pump | Mustafa Ayad | FLUENT | 0 | December 30, 2008 02:52 |
angular motion udf request | sonia | FLUENT | 9 | December 24, 2007 08:45 |
UDF angular velocity | mike | FLUENT | 0 | November 15, 2005 23:09 |
udf in MRF to update the rotational speed | Jam | FLUENT | 0 | August 21, 2005 12:50 |
