UDF Error while loading
Old   November 5, 2007, 01:50
Default UDF Error while loading
Sujay S
After building the UDF when i press the LOAD button i am getting the following error:
Opening library "libudf"... Error: open_udf_library: The system cannot find the file specified.
Error Object: ()
I have c compiler also
Thanks in advance
Cheers Sujay S
Old   November 5, 2007, 15:06
Default Re: UDF Error while loading
Jason
\do you Environment variables correctly?
Old   November 5, 2007, 22:44
Sujay S
Sorry, I don't get you
Old   November 6, 2007, 07:31
jason
Do you set environment vaiables when you install your C compiler? If not, you must do that.
Old   November 6, 2007, 07:42
Sujay S
i have installed a visual studio c++ version 6.0 in 64 bit machine. Do u know wheather it will work in 64 bit machine? and also can you tell me what should we set in environmental variable??
Old   November 6, 2007, 09:09
Jason
I don't Know about working of the fluent in a 64.0 bit machine but when you want to install the visual studio c++ 6.0 at one the last stages of installation it will ask you if you want to set enviironment variable and you just need to check it. You can also test this manner: Start->all programs->fluent inc. products->fluent6.0->set environment. (I'm not sure of this last)
Old   November 7, 2007, 00:48
vinse
hi, u check with the name of the directory. if u given any space in the directory name it may cause problem. once i also experienced this and i remove the space in the directory name and udf loaded
Old   November 12, 2007, 13:43
winter
is this problem solved? If not, let me know.
Old   November 12, 2007, 22:30
Sujay S
no. i am compiling in 32 bit machine and i am trying to use it in 64 bit machine is that a problem
problem loading UDF library in parallel cluster Veera Gutti FLUENT 8 July 26, 2016 07:24
problem with loading udf in fluent 6.3 James Fluent UDF and Scheme Programming 6 January 22, 2015 05:51
loading udf in parallel sytem tahere FLUENT 5 December 13, 2008 01:17
problem loading UDF in parallel fluent Tim FLUENT 12 July 12, 2008 12:59
Problems with loading udf Mukund FLUENT 6 July 6, 2004 02:13
