November 18, 2007, 09:23 |
problem with axysimmetric boundary
Hi all
Anyone could help me please? I have a problem with a 2-D geometry, I want use a edge as "axysimmetric", in Gambit is not problem. I have fixed the edges with a symmetry boundary at the centerline and two edges as Velocity inlet and pressure outlet respectively. But in Fluent, what have I to do? Supposedly I have to fix the property "Axysimmetric" (in Define--Model--Solver) but when I do that, I have problem when I check the mesh..Fluent say: Checking for nodes that lie below the x-axis. WARNING: Invalid axisymmetric grid: 1055 nodes lie below the x-axis. WARNING: Grid check failed. Thanks very much ! Nicolas |
November 20, 2007, 00:28 |
Re: problem with axysimmetric boundary
Hi for an axisymmetric problem, your whole domain must lie in the first quadrant. Thats the problem that you are facing. In gambit, move the domain to the first quadrant, or even in fluent, before changin the model to axisymmetric, translate the model to the first quad. apply inlet, outlet, wall and AXIS as the axis. it is imp to have a Boundary as Axis in a axisymetric problem
November 27, 2007, 15:48 |
means ur meshing should be in +ve X and +Y axis only...so shift ur meshing and ur problem will be solved...
UDS problem with wall boundary condition | Alex F. | FLUENT | 15 | September 21, 2015 09:28 |
[GAMBIT] 3D boundary layer and meshing problem in GAMBIT 2.4.6 | prashanthreddyh | ANSYS Meshing & Geometry | 1 | December 20, 2011 00:35 |
Boundary layer meshing problem in Gambit | Crystal | Main CFD Forum | 0 | June 12, 2009 14:32 |
problem boundary profiles | Rainy | FLUENT | 0 | April 24, 2008 05:30 |
GAMBIT problem with 3D Boundary Layer when meshing | Anthony Haroutunian | FLUENT | 2 | March 26, 2008 02:02 |
