udf help
hi
is it possible to run a seperate equation using udf in each time step at every cell? thank you |
Re: udf help
yes. you can do it with a UDS definition.
Re: udf help
hi max
thanx for your reply.can i make it in unsteady formulation? thank you once again |
Re: udf help
yes, you can find good helps in the UDF manual.
Re: udf help
thank u once again
hi i need to add this term as a source (8x2y2) x and y are the grid number or position ie 1,2,3.... wat macro i can use for solve this? |
