Granular TempEqn-How to DisableLaminarExchangeTerm
Old   December 11, 2007, 11:46
Default Granular TempEqn-How to DisableLaminarExchangeTerm
mrt
I use FLUENT 6.3 and try to model gas-solid (2 phase) flow (without any reaction taking place) using two fluid (or known as euler-euler) model. I am working in 2D (quite simple) domain.
I have a question about "granular temperature equation". Since I am not interested in turbulence modeling, I choose Model->Viscous Model->Laminar and as you know there is an exchange term at the right-hand-side of the equation which is added as -3*K*GranularTemperature (for laminar flows). Does anyone have any idea how to disable it? Or Should I write a source term UDF for granular temperature equation like â€"(-3KT)?
Many thanks…..
Old   December 11, 2007, 13:25
Default Re: Granular TempEqn-How to DisableLaminarExchange
bashu
(domainsetvar 3 'gt/zero-drag? #t)
Old   December 12, 2007, 03:47
mrt
thank you for fast reply....
though I couldn't follow you....can you please be a bit more specific? where to type this line?
Old   December 12, 2007, 14:42
bashu
just type in the fluent text interface.
Old   December 13, 2007, 05:39
mrt
Again thank you so much……I have some more questions though:
1 ) I am not so familiar with TUI â€" text user interface
> (domainstvar 3 'gt/zero-drag? #t)
gt/zero-drag?
If I push "enter key", I get main menu:
> adapt/ file/ report/ define/ …. display/ …. exit ….. Does that mean it is done??
2) I have one more important question: I would also like to disable the collisional energy dissipation term from the same equation (which is defined from Lun's equation) and write mine as UDF. Do you know how should it be?
> (domainstvar 3 'gt/zero-??collisondiss?????? #t)
3) Where can I get more information on "dominsetvar" ? Because info is not available in fluent official tutorials.
Thank you in advance,
Old   December 13, 2007, 08:11
bashu
1- Yes that's what it should do, I believe you can check by typing
(domaingetvar 3 'gt/zero-drag?)
2- I don't know how to turn the collision dissipation term off. Is there any reason you want to do that? just curious.
This is "scheme" language and you can find more here, not in English though.
http://www.cfd-online.com/Forum/flue...cgi/read/22755
Simulation of granular material Philippe Main CFD Forum 1 February 13, 2013 08:10
Eliminating exchange energy between phase in Granular Temperature diff eqn. cfdbusiness FLUENT 0 February 2, 2010 22:30
the maximum value of granular temperature haijj FLUENT 0 August 25, 2008 05:02
Multiphase Euler Granular Parameter Javier FLUENT 1 June 1, 2007 06:29
kinetic theory of granular flow problem user CFX 0 August 7, 2006 10:42
