December 9, 2007, 21:37 |
Multi-core systems - Fluent parallel
I know that a process on a 32 bits machine could use only 4 GB of RAM. On a multi-core system like Intel dual(quad)-core it is possible to use with Fluent parallel 8 GB of RAM ? |
December 13, 2007, 17:57 |
Re: Multi-core systems - Fluent parallel
yes but you need parallel licences. Also if you need >2Gb RAM per core then you need 64bit OS, hardware and Fluent version. In fact 32 bit Fluent can only access about 2-2.5Gb Ram per processor. On linux its about 3Gb Ram. But you can access more using 32bit application on 64 bit OS/hardware but 64bit needs 20% more memory on its own.
December 13, 2007, 21:16 |
Thanks
problem of running parallel Fluent on linux cluster | ivanbuz | FLUENT | 15 | September 23, 2017 19:12 |
parallel fluent setting in linux | m2montazari | FLUENT | 3 | October 10, 2011 16:42 |
Fluent parallel license problem | brothershuai | Main CFD Forum | 0 | July 1, 2009 15:41 |
FEDORA CORE and PARALLEL processing | Tuks | CFX | 2 | August 20, 2005 11:05 |
error parallel fluent session | Diet | FLUENT | 2 | January 27, 2005 12:31 |
