December 23, 2007, 01:13 |
Airfoil Analysis (drag coefficiet)
Hi, currently I am using CFD to analysis on an airfoil. And my question is about finding the spot for drag coefficient.
Here is what I did, I selected the forces under the report drop down menu. In there, I obtained drag coefficient by using the vector component. Once I have specified it, the forces as well as some other coefficients will be listed on the window. so here is my question; could someone please tell me which column and row that indicates the drag coefficient. Thank you so much. |
December 24, 2007, 05:10 |
Re: Airfoil Analysis (drag coefficiet)
Total force or total coefficient. But for coefficient you must specify your reference values (velocity, area etc.), which will be used for calculation of drag coefficient (report->reference.values).
December 24, 2007, 12:30 |
ha ok, thats mean more clear thank you al_c.
As for specifying the reference values, could you tell me which are these reference values more appropriate in my analysis? In my case the instructor asked us to select the pressure far field as reference values, but I did not get it why can't we select others reference values and what they are for. As for the total force, I suppose that is my drag force in my case right? I would appreciate if someone could answer this for me. Thank you |
December 24, 2007, 16:14 |
Usually density and velocity of ambient flow, wing area and ambient pressure are reference values for force coefficients of airfoil (in 2D case chord length instead of wing area).
As for the total force, I suppose that is my drag force in my case right? Yes, if you set right direction. Drag force operates in direction of ambient velocity vector. |
Airfoil negative drag coefficent | James Forrest | Main CFD Forum | 9 | September 5, 2022 10:30 |
Drag of Plunging Airfoil | mahzironrazak | FLUENT | 0 | October 19, 2009 18:41 |
airfoil optimizer chain with drag problem | Arnolm | OpenFOAM Running, Solving & CFD | 2 | October 18, 2009 13:43 |
Airfoil Analysis (Lift coefficiet) | Alex | Main CFD Forum | 2 | December 26, 2007 10:19 |
y+ for Airfoil Analysis | asd | Main CFD Forum | 3 | April 18, 2007 10:54 |
