January 3, 2008, 11:45 |
how to get rid of shadow wall
Dear All,
My main geometry (column) is a rectangle in 2D with Length = 10 m, Width = 0.2 m. and there is a side-outlet line at top and two side-inlets at bottom. So I have 4 faces (one main column, two-side inlets and outlet). Two-side inlet faces are connected to main column with two edges which defined as interiors in the boundary condition panel. After running the simulation like this for a few seconds, I would like to close one side inlet through changing the boundary condition from interior to wall. Then Fluent creates also a "shadow wall". I would like to know how to get rid of this shadow wall. What is the use of a shadow wall? (I choose the same conditions as I choose for that wall…does anyone have a clue how it is going to affect my solution?) with regards, |
January 3, 2008, 11:59 |
Re: how to get rid of shadow wall
Hey SSN shadow wall would not effect ur solution. its just created when u have common wall between two adjacent zones. wall is attached to one zone and shadow one is attached to other zone. and whatever u assign for wall would be assigned to the shadow wall too. wall and its shadow are sometime used to model thin wall between two volumes.
AJK |
January 3, 2008, 13:00 |
many thanks AJK...
Display Modes | |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 01:04 |
Very technical question about solving wall boundary layer ... | jlb001 | FLUENT | 6 | December 27, 2014 06:56 |
[Commercial meshers] tmerge utility creates unwanted interface/walls comes in the final mesh | Shoonya | OpenFOAM Meshing & Mesh Conversion | 11 | January 20, 2012 07:23 |
Wall Shadow interfering with Nusselt Number calculation? | ryzd | FLUENT | 1 | March 3, 2010 07:16 |
Shadow Wall | Soheyl | FLUENT | 1 | March 12, 2008 14:45 |
