how to get rid of shadow wall
Old   January 3, 2008, 10:45
Default how to get rid of shadow wall
ssn
Dear All,
My main geometry (column) is a rectangle in 2D with Length = 10 m, Width = 0.2 m. and there is a side-outlet line at top and two side-inlets at bottom. So I have 4 faces (one main column, two-side inlets and outlet). Two-side inlet faces are connected to main column with two edges which defined as interiors in the boundary condition panel. After running the simulation like this for a few seconds, I would like to close one side inlet through changing the boundary condition from interior to wall. Then Fluent creates also a "shadow wall". I would like to know how to get rid of this shadow wall. What is the use of a shadow wall? (I choose the same conditions as I choose for that wall…does anyone have a clue how it is going to affect my solution?)
with regards,
Old   January 3, 2008, 10:59
Default Re: how to get rid of shadow wall
AJK
Hey SSN shadow wall would not effect ur solution. its just created when u have common wall between two adjacent zones. wall is attached to one zone and shadow one is attached to other zone. and whatever u assign for wall would be assigned to the shadow wall too. wall and its shadow are sometime used to model thin wall between two volumes.
AJK
Old   January 3, 2008, 12:00
ssn
many thanks AJK...
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
Very technical question about solving wall boundary layer ... jlb001 FLUENT 6 December 27, 2014 05:56
[Commercial meshers] tmerge utility creates unwanted interface/walls comes in the final mesh Shoonya OpenFOAM Meshing & Mesh Conversion 11 January 20, 2012 06:23
Wall Shadow interfering with Nusselt Number calculation? ryzd FLUENT 1 March 3, 2010 06:16
Shadow Wall Soheyl FLUENT 1 March 12, 2008 13:45
