January 3, 2008, 05:15 |
axi-symmetric water jet surrounded by air
hai friends i would like to find out the centre line velocity decay of the jet of water issuing from the circular orifice, discharging into the quiscent atmospheric air.
how to simulate the above problem? the computational domain is 2d axi-symmetric. |
January 8, 2008, 01:52 |
Re: axi-symmetric water jet surrounded by air
January 8, 2008, 11:14 |
You'll probably want to use the VOF model. This model requires good nodal reolution of the interface. If your jet is more like a spray then this might be difficult. Also, transient works best and the NITA solver works good for speeding up time steps. Hopefully, that gets you started.
January 9, 2008, 10:48 |
thanks for your reply
I have used vof model. but there is no option to define (zone) water as "inletboundary" condition. fluent offers jones to faces and volumes but not for edges. i want to define "one edge" (inlet velocity) as water and remaining domain as air. plz give me your valuble suggestions. thank you |
January 9, 2008, 10:54 |
It should be available as long as you define the edge that you want as the inlet to be a separate zone when you mesh in Gambit. You will set it either as a mass flow inlet boundary or a velocity boundary--you will then specify the mass flow (or velocity) of each phase (water and air) on the boundary (set flow of air = 0 if that is the case).
Display Modes | |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
Water jet in confined hot air cross flow | Jim Clancy | FLUENT | 0 | November 24, 2007 16:14 |
TRAJECTORY OF A JET of water in air | np | Siemens | 0 | March 1, 2007 06:18 |
Simulating air jet into 2D & 3D water domain | Imran | FLUENT | 0 | June 6, 2006 08:57 |
Help!!!problems in air jet into water bath | kim | FLUENT | 4 | June 9, 2003 07:04 |
