July 12, 2014, 08:19 |
Advices about cavitation/single phase flow
Rick
Rep Power: 26 |
Hi all my friends,
I'm studying a problem in which cavitation is involved and it's not negligible in the domain. The domain in mainly composed by a series of rotors and I'm trying to solve the problem by mrf and sliding mesh. Physics of the problem should require turbulent +multiphase (mixture) + cavitation models, however I'm having a lot of problems in converging the solution because as you know, cavitation problems are in general difficult to converge. Main goal is to calculate power required by the rotors. So, I was thinking about running my problem in single phase flow: Options are: 1- Loop across cells and faces at every iteration to find pressures<vapor pressure and force them to the vapor pressure (UDF) 2- Let cells and faces to have negative absolute pressures, and later considering that in these cells cavitation occurs So my question: a) Does it make sense to run my problem in single phase? b) If a) is true, what's the best option between 1) and 2)? Thank you, Daniele |
Display Modes | |
coupling vof with single phase flow and gravity term | alame005 | Main CFD Forum | 0 | August 2, 2013 14:37 |
Two Phase Darcy flow with gravity -> problem | Cyp | OpenFOAM Programming & Development | 0 | November 17, 2010 07:58 |
two phase flow + ice phase and breaking | soeren87 | OpenFOAM Running, Solving & CFD | 0 | September 19, 2010 10:20 |
Validation for laminar Disperse phase flow | shashwat | Main CFD Forum | 0 | April 4, 2008 02:20 |
how 2 freeze 1 phase flow field & start lagrangian | KK | CFX | 5 | February 14, 2008 16:48 |
