interface
Old   January 14, 2008, 09:34
Default interface
rym
hi every one i want to studie the flow simulations in the stirred tanks for this i use silding mesh but i can't undrestand how i can use interface between stationary and rotating blocks can any one help me thanks
Old   January 14, 2008, 17:31
Default Re: interface
red lemon
create a mesh for the rotating part and completely separate mesh for the static part. Each should have a surface mesh for the sliding surface of revolution. Then tmerge together or append grid then define>grid interfaces and set moving fluid as MRF zone.
Old   January 16, 2008, 04:55
rym
thanks for this information I used this way but the velocity of fluid is different of zero only in the rotating zone in the static part the velocity is zero and i want to know what is the difference between moving mesh and moving reference frames thnks any way
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
CFX Solver Memory Error mike CFX 1 March 19, 2008 07:22
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
