January 20, 2008, 09:19 |
Reading and Writing Boundary Conditions
I'm using Fluent 6.3 and I want to apply the same boundary conditions for different cases. In my simulations, I am just varying the mesh and not the model or conditions. How do I do that? I read that I could go to file -> write-bc, but there's no such option for me!! Help! Many thanks!! Chen |
January 20, 2008, 15:41 |
Re: Reading and Writing Boundary Conditions
Try writing a journal file, and running it in TUI...so in that case , u just have to read different mesh file thats all, everything else will be taken care by the journal file..
for more help, try http://cfd-online.com/Wiki/Fluent_FAQ |
January 20, 2008, 21:11 |
Hey thanks for your quick reply. I'll try it out and get back to you.
Thanks. chen |
January 21, 2008, 15:17 |
You can file --> write_bc from the text interface (TUI) only. In the text window, type: File then hit enter.... you should see multiple options. You want to write a boundary condition file, so type: write_bc
Yoiu then specify the file name you want for the boundary condition file (or it will default to the name "bcon" |
Segmentation Fault in fluent3DMeshToFoam | cwang5 | OpenFOAM Bugs | 23 | April 13, 2011 15:37 |
solid to fluid heattransfer with chtMultiRegionFoam | nakor | OpenFOAM | 11 | March 21, 2011 08:28 |
[Commercial meshers] TGridFluent mesh with internal by prism layer and internal face for diagnostic | sponiar | OpenFOAM Meshing & Mesh Conversion | 2 | March 30, 2009 15:02 |
COUPLING BOUNDARY CONDITIONS UNDER WINDOWS | Jiri Novak | FLUENT | 3 | July 25, 2005 11:04 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
