3D CFD importing
Old   January 28, 2008, 23:17
Default 3D CFD importing
corey
hi, iv recently just begun using gambit/fluent for a final yr project and would realy appreciate some help on this. I am analysing the flow around the rear wing of a race car and have now come to doing some 3d investigations.
i have made my model/assembly in solidworks, and would now like to know, what is the best way to import this into gambit for meshing. i know this is probably one of the easiest/dumbest questions out there but i have tried a few different methods and nothing seems to work...and im getting pretty frustrated.haha
anyways, if anyone could help me on this it would be greatly appreciated. thanks in advance
Old   January 29, 2008, 02:11
Default Re: 3D CFD importing
mAx
if your direct import your solid geometry, you will have ton extract the fluid domain. This is simply accomplished by substracting your computational domain with your solid domain. Or you can directly create your fluid domain within your CAD Package
Old   January 29, 2008, 09:00
madhukar
Hi
If u want to mesh a CAD model in gabit by importing it, u have to build the model in CAD as a single part(not an assembly). Save ur solidworks model as a Parasolid(x_t) file and then import it from Gambit file menu.
hope this helps
regards,
Madhukar
Old   January 29, 2008, 09:07
mAx
you can also import your assembly as Step File into gambit. (no problem with assembly)
Old   January 29, 2008, 16:26
corey
ahh ok isee, thanks for the replies.
i will have to try these things out. is it simply by just saving it in solidworks as a parasolid?? and that is .xt
i will let you know if i run into any more trouble, which is more than likely.haha
thanks once again.big help
STAR-Works : Mainstream CAD with CFD CD adapco Group Marketing Siemens 0 February 13, 2002 12:23
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 21:10
ASME CFD Symposium, Atlanta, July 2001 Chris R. Kleijn Main CFD Forum 0 August 21, 2000 04:49
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 12, 1999 23:27
CFD Symposium (Call for Papers) Chris R. Kleijn Main CFD Forum 0 October 5, 1998 10:25
