NOx model
Old   February 2, 2008, 10:46
Default NOx model
Phil
Hi there,
I'm trying to use the NOx model in Fluent, for both thermal and prompt NO, but the results are drastically under-predicted.
The solution I'm using gives reasonable agreement with experiments, but the NOx levels are underpredicted by a factor of around 100.
I'm using the partiall-premixed flamelet model, with a 37 species reduced methane mechanism. It says in the user guide that the premixed model is incompatible, but that the partially premixed is compatible. Anyone have any ideas?
Any help is very much appreciated. Thanks Phil
multiphaseInterFoam for RAS turbulence model chiven OpenFOAM Bugs 8 December 6, 2017 02:08
help for different between les model (subgrid-scale model) liuyuxuan FLUENT 1 October 2, 2009 15:25
2 stage axial turbine model convergence issues sherifkadry CFX 2 September 7, 2009 20:51
multi fluid mixture model issue rystokes CFX 3 August 9, 2009 19:13
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 03:27
