advantage of having orthogonal mesh
Old   February 2, 2008, 11:08
Default advantage of having orthogonal mesh
Usman
Hi, If a mesh lack orthogonality in regions with large contour deflectios,e.g at an airfoil leading edges, what will be the disadvantages? many thanks,
Old   February 4, 2008, 09:34
Default Re: advantage of having orthogonal mesh
jesse
may drive the solver into divergence extreme unorthogonality cause the most problem for FVM solver
Old   February 4, 2008, 11:53
PKN
probably false diffusion with non-orthogonal mesh......pls correct me if I'm wrong.
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel colinB OpenFOAM Meshing & Mesh Conversion 14 December 12, 2018 08:07
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
[snappyHexMesh] non-smooth mesh Svensson OpenFOAM Meshing & Mesh Conversion 11 January 18, 2012 09:13
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
