Heat flux BC in axisymmetric case
Old   February 7, 2008, 18:07
Default Heat flux BC in axisymmetric case
kevin
I am modeling a simple cylinder using an axisymmetric mesh. I have added a heat flux BC at the top boundary with a DEFINE_HEAT_FLUX UDF. The heat flux profile is a top-hat extending a distance r0 from the symmetry axis. The heat enters the mesh in the axial direction. However, when I run this case in steady state, the solution never converges despite mesh refinements and adjustments to the relaxation parameters. When I run the same UDF in a 3D model of the same geometry there is no problem. Do I need to add something to the UDF to account for the axisymmetric nature of the problem? Thanks!
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
heat flux distribution gtheo CFX 2 April 27, 2011 03:36
Heat Flux Wall Boundary Confusion. Joee FLUENT 1 August 21, 2010 12:20
Wall Heat Flux not a listed variable mike CFX 8 February 5, 2009 13:32
Help needed for extracting Heat Flux from Fluent Piotr FLUENT 1 July 11, 2006 11:59
