January 25, 2008, 14:34 |
Without Inlet and outlet
Is it possible to solve a problem without Inlet and outlet boundary condition in fluent? Only walls rotational condition is there.
If anybody has knowledge of StarCD, Please share there view about this and possibility in StarCD also. |
January 27, 2008, 01:46 |
Re: Without Inlet and outlet
If u can describe ur problem then suggestions can be made. ur question is too broader to answer, any way u need to specify the boundary conditions at the boundaries not necessarily inlet or outlet. please specify ur problem more clearly bye |
January 27, 2008, 08:41 |
Thanks for reply.
This is small domain near to gears which is engaged and fully submerges in oil. Due to rotation of gears fluid would shear and splash out from both sides. But both sides are inside Fluid domain. I tried this by giving Atm. Pressure inlet and no outlet. But solution is not converging. Please advise |
January 28, 2008, 02:22 |
Hi, if you are trying to model only the space with in the gears you can use pressure outlet if you can predict the pressure or if you dont konw any thing you can simply specify the outflow boundary condition at the openings in fluent.
working on 2d problem or 3d hope this will help you bye |
February 11, 2008, 12:45 |
Hi Chetan,
You can let me know the problem in little more detail, what results you want to check without Inlet or outlet and if you can share your contact details, i will check and revert on receipt of your problem details. |
Mass flow inlet and pressure outlet issue | nikhil | FLUENT | 5 | December 11, 2013 12:30 |
Pulsatile pressure inlet with pressure outlet | a.lynchy | FLUENT | 3 | March 23, 2012 13:45 |
steam flow in a pipe driven by a pressure gradient between inlet and outlet | SalvoCalvo | COMSOL | 0 | March 11, 2010 06:52 |
VOF Outlet boundary condition in cfd - ace | JM | Main CFD Forum | 0 | December 15, 2006 08:07 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
