HELP PLS.........
Old   February 15, 2008, 12:09
Default HELP PLS.........
vijayaragavan
Hi friends can any body please help me to write an UDF for Velocity inlet with respect to time for following readings please........ Or please send me some help file related to this friends...... Thanks in advance......
Time(s) - 5 3 7
Velocity(m/s) - 5 10 8
Thanks for ur reply friend.......
Regards, Vijay
Old   February 18, 2008, 09:07
Default Re: HELP PLS.........
James
are you trying to specify your vel profile as a step function or what?
If so, you need to use a UDF with an array that would allow you to specify for a given number of time steps, the velocity...
I assume you are running an unsteady simulation?
Good luck.
James
HELP PLS: Simplefoam manipulated to add diffusive mass transport...but solver stops!! 1gn0rant OpenFOAM Running, Solving & CFD 1 August 13, 2010 11:02
help me understand porous media in fluent~ pls pls.. :( naftalena FLUENT 0 February 28, 2010 12:20
i need help following problem pls pls help gmani CFX 4 March 31, 2009 09:39
Turbulence model for subsea stability, Pls. Abiodun FLUENT 1 August 23, 2007 06:52
multi phase flows....pls help... karthik FLUENT 0 November 16, 2005 09:15
