Error in parallel computing
I am running a cas/dat file on 8 compute nodes without using GUI. I got error information such like: reversed flow in 1682 faces on pressure-outlet 18. turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 53820 cells Error: > (greater-than): invalid argument [2]: wrong type [not a number] Error Object: inf # invalid command [#] max number of iterations Warning: An error or interrupt occurred while reading the journal file. Some commands may not have been completed. > Halting due to end of file on input. However, if I use GUI to run the model, there is no such problem. What is the reason for the error? Is it due to the partition of grid? By the way, I use the auto-partition. Thank you in advance. |
Re: Error in parallel computing
i am sorry i cant help u .. but u can surely help me .. how ca n i make both of my cores work simultaneouly .. apending -t2 in the shortcut did give me a feel that something is goin to happen ..but alas!! the CPU utilization showed only one core working at full capacity ... plz help me ..how to do it
Anup,
Hope that I can help you though I am waiting for help too. But what is your problem ? |
i already wrote it .... how can i make both of my cores work simultaneouly .. apending -t2 in the shortcut did give me a feel that something is goin to happen ..but alas!! the CPU utilization showed only one core working at full capacity ... plz help me ..how to do it.. i hv pentium D 2.8ghz
