March 5, 2008, 09:13 |
Continuity si not converged
I'm modelling a gas turbine combustor with an unstructured grid. I've got a problem for the continuity residuals. I don't think it's a problem related with the grid.
March 5, 2008, 09:18 |
Re: Continuity is not converged *NM*
March 5, 2008, 09:20 |
Re: Continuity si not converged
Maybe...but many things can cause it.
March 5, 2008, 10:23 |
I tried several unstructured grid (sensitivity analysis). Could I change under relaxation factor?
March 5, 2008, 13:03 |
Decreasing of under relaxation factor usually help. Especially the Momentum under relaxation factor.
March 6, 2008, 19:50 |
Decrease under relaxation factor. first momentum, if it not sufficient then try with pressure also.
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
