Combustion Instability in Gas Turbine Combustors
Old   March 6, 2008, 10:50
Default Combustion Instability in Gas Turbine Combustors
yoyo
Hi, Mates,
In terms of combustion instability resulting from the coupling of heat release with pressure oscillation, how to define the inlet and outlet boundary conditions? To my knowledge, the compressible effect should be taken into consideration, is it?
Any one could show me some experimental data regarding, in particular, the case of liquid fuel?
thx.
Old   March 6, 2008, 20:51
Default Re: Combustion Instability in Gas Turbine Combusto
NRD
You are right. Compressibility effects need to be taken into account to study combustion instability. You can find vast literature on the topic of combustion instability in AIAA papers, Journal of propulsion and power etc. The "Theoretical and Numerical Combustion" by Poinsot and Veynante has an excellent chapter on Combustion instability.
Old   March 7, 2008, 03:19
yoyo
Thanks a lot, NRD. But, LES is adopted by nearly all the cases with respect to C.I. discussed in that book mentioned by you. As far as URANS is concerned, defining suitable boundary condtions is a headache for me, considering both the compressibility effects and wave motion at the inlet and outlet.
Any suggestion about that?
Old   March 9, 2008, 08:43
SA
yes read more and more hehheheh
Old   March 16, 2008, 06:39
Djamel
How i can do the simulation withote combustion of non premexide combustion with FLUENT for confirm that the melonge is rechese
comment je peut faire la simulation de sans melange sans combustion dans FLUENT
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Gas turbine Combustion modelling.. achinta OpenFOAM 0 June 15, 2010 09:25
OpenFoam for Gas Turbine Combustion Radek Main CFD Forum 1 August 13, 2006 08:24
Gas Turbine Combustion Q Main CFD Forum 13 August 12, 2006 15:45
