coupled (thermal analysis)
Old   March 13, 2008, 22:30
Default coupled (thermal analysis)
Sellyg
Dear All,
I have searched the forums already and didn't find the solution to the problem I am having.
We want to evaluate the thermal conduction in the wall of the one cylinder (there is fluid moving into cylinder) On the external wall I specified temperature, both what bc I most use the internal wall?
thanks
Old   March 14, 2008, 03:32
Default Re: coupled (thermal analysis)
selvag
hi, you can specify the internal wall (wall which shares solid and fluid) as coupled. first you need to change that shell from interior to wall then in bc panel u can choose coupled. it will automatically take the value.
Old   March 15, 2008, 15:11
Sellyg
Hi, I don't know to do what you wrote. Help me. ...to change that shell from interior to wall...
Old   March 17, 2008, 22:54
selvag
the face which is in between solid-solid or solid-liquid will appear as interior in bc panel. you need to change that face from interior to wall and wall sub panel will open and choose coupled and click ok. now you will get one more face in the same name+shadow. hope it will help
should i use fea or cfd for thermal analysis? mr. bill FLUENT 7 March 3, 2016 14:31
thermal boundary condition at coupled wall gokul patil FLUENT 2 June 19, 2014 05:07
thermal analysis raffap Siemens 7 May 23, 2011 02:08
Coupled analysis Rosco FLUENT 2 January 13, 2003 05:27
thermal analysis nick Main CFD Forum 3 October 28, 2001 18:03
