March 16, 2008, 00:44 |
Free Surface Effect on the AUV
Dear All,
I am simulating the water flow over under-water body and calculate the drag force acting on it. I want to set the upper surface as free surface and investigate the effect of wave at the free surface on the immersed body. Have you any experience in this field? With Best Regards. Mahbub |
March 26, 2008, 05:11 |
Re: Free Surface Effect on the AUV
can you give me this file"http://www.dt.navy.mil/hyd/tec-rep/vis-dra-cal/documents/viscous.pdf",thanks!my emial is: dongtaomail@gmail.com. are you studied on the podded propulsor?
surface tension gradient on a free surface | Abrem | FLUENT | 1 | April 30, 2006 03:41 |
VOF and strong surface tension effect | phsieh2005 | Main CFD Forum | 1 | August 30, 2005 06:56 |
Multicomponent fluids with strong surface tension effect | Pei-Ying Hsieh (Hsieh) | OpenFOAM Running, Solving & CFD | 1 | January 11, 2005 07:35 |
free RANS code with free surface ability | Lou jing | Main CFD Forum | 1 | July 11, 2003 14:43 |
[surface tension effect at free-surface ?] | name | Main CFD Forum | 1 | September 21, 2001 09:54 |
