export mesh to GAMBIT
Old   April 4, 2008, 14:50
Default export mesh to GAMBIT
manu
How can we export a complete mesh that can be imported in GAMBIT from a .cas and .dat file?
Old   April 7, 2008, 02:06
Default Re: export mesh to GAMBIT
mAx
File/Import/Mesh --> Type Fluent
Old   April 7, 2008, 04:49
manu
Do you mean import a .cas file? Yes I've already tried but it doesn't work. I get am error: Gambit is unable to open...
Don't we need to export the fluent grid in a .msh or dbs file??? so that it can be read in Gambit
Please help me.
Old   April 7, 2008, 05:13
mAx
no you can't export in *.msh or *.dbs how did you import the mesh file into fluent?
Old   April 7, 2008, 06:34
manu
I suppose with a .dbs or .msh file from Gambit... The point is that I don't know because I took directly a .cas and .dat file from a colleague who doesn't work in my office anymore and nobody knows where the Gambit grid is... Now I'd like to know how to import this grid in Gambit again from a .cas file to modify it...
Old   April 7, 2008, 07:30
mAx
ok, I create a simple cube in gambit, and I meshed it and exported it in hexa, tetra, tetra-hexcore and I converted also the last one with "tpoly" utility. I could re-import the *.cas in Gambit for hexa, and tetra meshes. With the 2 others, it is not possible, because of the hanging-nodes , and/or polyedral cells. So I assume your mesh contains hanging nodes or polyedra. Check with your support, for fixing this problem. Sorry for not being able to help you furthermore
Old   April 7, 2008, 08:26
mAx
Check if you can export the mesh in CGNS format. If yes, try to import it, into gambit (this is in case of hanging nodes (no polyedra))
Old   April 8, 2008, 07:33
manu
Yes it does contains polyedral cells... So in all the cases, thanks for the info. I'll look at the problem more deeply with the support
Old   April 8, 2008, 16:21
red lemon
Polyhedral or hanging node (eg adapted) meshes cannot be read back into TGrid or Gambit. Fluent case files can be read into Gambit (assuming neither of the above) by writing out case as unzipped and in ASCII format. Then use File>Read>Mesh in Gambit to read in mesh into Gambit and virtual geometry will be created from mesh (creates faceted geometry). You may be able to convert to real but this depends on the case. You can unadapt adapted meshes in Fluent back to original density before transfer but polyhedral meshes cannot be converted back so need to be saved before conversion (even based on skewness only changes or a tploy'd hexcore mesh).
Gambit mesh export Satya Main CFD Forum 1 May 26, 2004 17:06
gambit export 2d mesh SHANKAR FLUENT 3 April 25, 2004 23:47
Export mesh back to Gambit Paul FLUENT 3 March 30, 2003 07:47
Export gambit generated mesh moiami FLUENT 0 March 3, 2003 02:53
GAMBIT merge and export mesh sean FLUENT 4 March 8, 2001 07:50
