April 7, 2008, 13:19 |
RSM with Eulerian, tips for convergence?
I'm running a RSM unsteady simulation with Eulerian multiphase enabled with two phases (a gas and a particle stream). I'm having trouble getting it to converge however. I'll get a few seconds into the simulation and then I start getting errors followed by the inevitable "floating point exception".
Anyone have any tips on how to get it to converge? |
April 9, 2008, 07:19 |
Re: RSM with Eulerian, tips for convergence?
April 9, 2008, 13:01 |
The RSM isn't the problem. I can solve the model using only RSM, its when the Eulerian is enabled that I'm getting problems.
April 9, 2008, 13:25 |
Okay let me explain in a little more detail what I've done:
I am attempting to run a simulation of a cyclone using the RSM-unsteady-eulerian multiphase model. Previously the model has converged using RSM-Unsteady with no multiphase model. I ran with the multiphase enabled (2 phases), and I kept getting floating point errors once I got to a certain point (around 4s). I checked fluent's manual and they suggested running the simulation without volume fraction selected in the solution menu until convergence. I ran this model until the solution conditions were basically steady state (no changes in results for varying time steps). I then reenabled the volume fractions, but it soon bombed out due to the "turbulent excursions". I then tried turing the turbulence equations off in the solution, and have been running it since. I'm around 48s, and based on the results I have it is nowhere near convergence. I'm running with a time step size of .001s which converges in about four iterations, however when I try to increase the size the residuals diverge wildly. Anyone have any suggestions about what I can do (preferably with all the solution equations (turbulence/volume fraction) enabled)? |
Singularity in two fluid model (Eulerian-Eulerian) | Zak | Main CFD Forum | 4 | February 28, 2010 17:54 |
Eulerian-Eulerian for 1% dispersed phase | Kushagra | CFX | 1 | May 23, 2008 04:03 |
Convergence tips | John | CFX | 3 | August 28, 2005 01:15 |
Convergence of Eulerian-Lagrangian part. tracking | Sven | FLUENT | 4 | July 30, 2004 05:34 |
enabling UDS in Eulerian-eulerian multiphase model | shao1 | FLUENT | 0 | July 14, 2002 22:23 |
