Velocity profile as an velocity intlet condition
Old   April 15, 2008, 11:34
Default Velocity profile as an velocity intlet condition
kees
how can i use the velocity profile as an velocity inlet condition in fluent
Need help
Regards
Old   April 15, 2008, 17:42
Default Re: Velocity profile as an velocity intlet conditi
AAA
Hi
Are you trying to create a velocity profile of your own that has a unique shape? Please provide more detail.
Regards
AAA
Old   April 16, 2008, 17:14
kees
i am trying to model a pipe in which the velocity profile obtained at the outlet to be used as an inlet condition for a same pipe but smaller in size
yes you can say that i am trying to create a velocity profile (on inlet) that has a unique shape
hope i have explained it well
i am making a microflow in a microsize pipe for which i want to put the velocity profile at out let to be an inlet condition so that the flow is already developed ...
Old   April 16, 2008, 18:35
AAA
Hi
Is this a 2D or 3D case?
If the two pipes were of the same diameter, I'd suggest that you go to Define--> Profiles, and write the profile at the outlet in the first pipe. Save it in the same folder that the new pipe exists in. Read this profile in the new case after reading it. In the velocity inlet, Assign the profile to it.
When working with two different diameters, I'd read the profile of the large pipe into Excel, cutom it to what I want, putting in mind that I get the right mass flow rate, and then read it again in Fluent.
The number of grid points at the two profiles is important.
I hope this helps
AAA
velocity profile inlet boundary condition question Lcw FLUENT 3 August 3, 2012 05:53
velocity profile as an velocity inlet condition KEES Main CFD Forum 0 April 15, 2008 11:26
Profile Data Velocity Boundary Condition Changes?? Maria Angelica CFX 9 June 14, 2006 02:44
3d velocity profile zwdi FLUENT 2 February 10, 2004 14:26
particle velocity and velocity profile HGG FLUENT 2 June 10, 2001 16:32
