April 15, 2008, 15:15 |
meshing jet case
I'm having trouble meshing a jet case that I'm working on. The problem is that I need to include a really large area around the jet (relative to the jet/nozzle size)- about 20D by 50-100 D. I was able to get a good mesh for one nozzle, but now I am usign several nozzles, which exacerbates the problem because I need to mesh the space between the nozzles and because the jet formed by the nozzles is larger. I need to have a fine mesh in the nozzles, a finer mesh in between, and a coarse mesh far away from the jet.
To make a long story short, I was wondering if anyone could suggest a way to mesh a case where both large and small geometries are present? The mesh needs to be very fine in some areas, but I would like it to be coarse in other ares to prevent the case from being too large. I am having trouble doing this using a structured mesh in Gambit. |
April 15, 2008, 17:31 |
Re: meshing jet case
Hi
Have you tried using Size Function? It works very well with such complex geomentries. Also, you should consider sub-dividing the domain into smaller zones in order to have better control over the meshing procedure. Regards AAA |
Hexa meshing or Tetra meshing??? | NITIN DEWANGAN | CFX | 5 | August 5, 2008 09:59 |
Cloning a case or creating a new case for 16 processes | mellanoxuser | OpenFOAM Running, Solving & CFD | 0 | February 8, 2008 16:52 |
Problem seeing new case in case browser | alan_fergus | OpenFOAM Pre-Processing | 9 | June 22, 2006 03:46 |
Singularity of grid?Volume meshing vs face meshing | Ken | Main CFD Forum | 0 | September 4, 2003 11:09 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 11:08 |
