Temporal Velocity XY Plots
Old   April 29, 2008, 08:54
Default Temporal Velocity XY Plots
Stephen Smyth
Can anyone tell me how to produce an XY plot of velocity and distance at differing phase angles for a temporally varying system?
Any help appreciated, thanks.
Old   April 29, 2008, 14:51
Default Re: Temporal Velocity XY Plots
AAA
Hi
You can do this using the: Solve-->monitors-->surface.
Regards
AAA
Old   May 8, 2008, 06:37
Stephen Smyth
Thanks for the pointer.
I have been able to study the temporally varying Y velocity at given points on the Y-axis using this technique, however, I would like to be able to produce a complete velocity profile for the centerline emanating from the jet orifice at given phase angles. Setting up points and studying them individually would prove extremely time consuming, is there any other method of doing this?
Thanks
Old   May 8, 2008, 15:08
AAA
Hi
You can create a line/rake for this task. Go to Surface--> line/rake. Doing so, you can examine results at specified lines. Also, creating an iso-surface along the centreline might be feasible too.
Regards
AAA
Old   May 8, 2008, 15:52
Stephen Smyth
Hi
yea, I have produced a line to take my measurements on, however, if i monitor Y velocity against time steps it gives a single value calculated as an average for the whole line, rather than a value for every grid node along the line which would show a profile along its length at each time step, which is what I require to study the velocity at given phase angles.
Thanks
Temporal accuracy ganesh Main CFD Forum 0 February 29, 2008 05:32
temporal and spatial discretization. pity Main CFD Forum 0 June 10, 2007 22:53
rms velocity plots David FLUENT 1 November 8, 2006 10:35
Spatial and temporal discretization Giuseppe FLUENT 2 January 23, 2006 05:18
Temporal differencing for LES Jongtae Kim Main CFD Forum 0 June 2, 1999 23:09
