difference in results...
Old   May 21, 2008, 00:50
Default difference in results...
mateus
I'm simulating flow in an open valve (it's almost only a pipe). First I did a simulation with mass flow inlet and pressure outlet bc. When I checked the results the pressure difference upstream and downstream of the valve was about 30% too high. In the second simulation I set the pressure inlet and pressure outlet bc and checked the flow rate. This time the results were correct. If I repeat the simulation giving the last flow rate as a bc and check the pressure difference the result is again wrong.
Has anyone encountered something like that...such a influence of the (in essence the same) boundary conditions?
Thanks for the answers Mateus
difference in results between 2D and 3D Michelle CFX 3 December 10, 2007 01:59
Difference in pressure drop results To all fluent users need help pls FLUENT 4 May 30, 2007 04:31
Difference in pressure drop results al-jasim FLUENT 0 May 28, 2007 09:54
Difference results between Steady and Unsteady? Giang T Vu FLUENT 6 May 22, 2004 06:37
Difference in results using different Mesh? Julie FLUENT 7 July 2, 2002 10:28
