Kelvin Helmholtz Instability problem
Old   May 30, 2008, 12:29
Default Kelvin Helmholtz Instability problem
nadav wetzler
Hi, I build a KHI model : 4m by 10m rectangular mesh with 50K cells, two layers (the light one above the heavy ) . I use a VOF model and I perturbate the interface between the two layers with a sin function. The problem is that when I run the model, the bottom layer is moving out of the mesh. I use boundary conditions of: velocity inlet (on the left) and pressure outlet (on the right). I normally patch the bottom layer to the phase 2 . I tried to patch the top layer but it didn't help much. How do I keep both of the layers in the mesh?
Thanks
Nadav
Old   July 10, 2009, 11:44
Andrea Da Ronch
adr_adr is on a distinguished road
I try to simulate the KH instability by two fluids with different properties (density & velocity) in a 2D domain. I have used a patch file to give the initial conditions. I have got some different instabilities playing with the densities & velocities of the fluids.
Though, I have a doubt.
Is gravity necessary to lead the instability? Our code was intended for high speed for aircraft & gravity is not included. As a consequence, I did not obtained yet the "cat's eye" shape of instability.
Thanks for any advice.
Andrea.
adr_adr is offline   Reply With Quote
Kelvin helmholtz instability must be necessary to HoJun CFX 1 April 29, 2008 18:49
Kelvin Helmholtz instability Gopal CFX 0 July 15, 2006 11:05
About Kelvin Helmholtz Instability? leaf Main CFD Forum 1 May 31, 2006 11:34
Kelvin-Helmholtz instability pierre FLUENT 0 June 17, 2002 11:35
Kelvin-Helmholz Instability??? Anan Main CFD Forum 2 April 6, 2000 05:17
