Courant number selection
Like Tree2Likes
  • 1 Post By fadhil
  • 1 Post By max
Old   June 2, 2008, 21:29
Default Courant number selection
Woo
Dear all,
I am using the pressure-based coupled solver. This pressure-velocity coupling method requires input of the Courant number. the default value in FLUENT is 200. I think i need to lower this value for better convergence. Any idea how to select a proper value?
Best regards, Woo
P.S. I have gone through the archives. It seems that 0.5 is always referred as a low value. Not sure why it is so.
Old   June 3, 2008, 03:55
Default Re: Courant number selection
fadhil
try 0.1
Old   June 3, 2008, 04:04
Woo Meng Wai
Hi Fadhil,
Thanks for the advice. May I know the reasoning in choosing 0.1 or perhaps thre is a calculation that we can use?
Best regards, Woo
Old   June 3, 2008, 04:08
fadhil
try 0.1
Old   June 3, 2008, 04:24
fadhil
courant number is ratio of a time step to a cell residence time..so choose the small ratio.
Old   June 3, 2008, 04:42
fadhil
try 0.1
jn10hn likes this.
Old   June 3, 2008, 05:11
max
Hello Woo,
the Courant-Number limit < 1 must be adhered to for explicit time discretitation schemes, especially for Vof-applications or certain high Mach-number flows with shocks where one should use density-based coupled solvers. For single-phase flows or incompressible fluid dynamic problems I met no stability problems using a Courant-number of 20 with the pressure-based coupled solver, provided that you have a good quality grid.
cheers
Max
jyothsna k likes this.
Old   June 3, 2008, 06:12
Woo Meng Wai
Hi Max,
Thank you for the advice. No wonder my model failed to converged at the default value of 500. Will try the lower number and see what happens.
cheers, Woo
On the Courant number . raintung FLUENT 4 June 2, 2016 12:26
mach number and selection of the fluent solver turbinesv FLUENT 4 April 24, 2011 00:14
Courant number 999.999 PetrK CFX 3 December 15, 2005 11:07
courant number cfdbig FLUENT 2 August 16, 2004 08:17
Courant Number Parshant Dhand FLUENT 1 April 29, 2003 20:39
