June 12, 2008, 09:25 |
Gambit/Fluent: Fence Porosity - Option?
Hi there,
I want to simulate the airflow through a fence with a certain porosity, but I want to avaoid constructing it with gambit, because it is very difficlut to get a good quality mesh. Is there some kind of option, so that I can use a line instead and just give thise line the property of beeing this line with the porosity or maximum flow rate through it? THX in advance, Andreas |
June 12, 2008, 17:05 |
Re: Gambit/Fluent: Fence Porosity - Option?
use porous jump.
June 13, 2008, 08:01 |
hi red lemon,
could you please tell me the path of this menu option? I haven't heard this option and I don't know, where this is in gambit oder fluent. greets, Andreas |
June 13, 2008, 08:29 |
set up the grid in gambit with the fence as an interior zone (facial interior as a connected but shared face). Then change the zone type in fluent to porous jump using the define>bc panel. Then set your loss coefficients. If 3d fx are important then use porous media instead.
June 13, 2008, 17:14 |
hi and thx for your help. I tried to build the model according to your tips, if I understood them right.
horn.hdtvtotal.com/download/poroustest.zip is that right in concept?(it just a quick test to have a qick result before doing the right model) do I really have to do 2 seperated faces/areas like shown? greets, Andreas |
Display Modes | |
Gambit split volume option | John peter | FLUENT | 2 | May 2, 2011 22:29 |
Fence with Porosity, no additional data. How? | Andreas Hornig | FLUENT | 0 | September 10, 2008 05:08 |
How to use blend option in Gambit | Sudhir | FLUENT | 2 | September 29, 2007 15:54 |
How to use boundary layer option in gambit | san | FLUENT | 0 | May 5, 2006 00:41 |
Export option In Gambit | krishna | FLUENT | 9 | April 12, 2004 08:04 |
