August 2, 2002, 06:46 |
Turbulent Schmidt Number
Hi. For the past few months I have been modelling the movement of neutrally buoyant dye through a pipe with the species model in Fluent 5.5. I have found that altering the turbulent Schmidt number from 0.5 to 1.5 makes a 300% difference to the results. I know Fluent claims that a value of 0.7 is generally OK, but does anybody know if there is more detailed information for pipe flow. Thanks John
August 13, 2002, 07:06 |
Re: Turbulent Schmidt Number
I don't know about your precise configuration or modelling practices, but for classical developed pipe flow with passive heat or species transport, the turbulent Prandtl/Schmidt number varies from around 0.9 at the wall to 0.6 at the flow axis. Experimental data exists which permits determination of the Prandtl number variation across the pipe. It can be deduced from measurements of the mean velocity profile, mean concentration profiles and the radial profiles of the Reynolds shearing stress and radial turbulent concentration/heat flux.
August 13, 2002, 13:08 |
Thanks for your reply. Can you give me the reference for variation in the turbulent Schmidt number for a pipe? Also is the Prandtl and Schmidt number the same thing? Thanks once again. John
August 14, 2002, 06:50 |
I will dig out the reference. The Prandtl and Schmidt number will be the same when dealing with passive contaminents.
August 15, 2002, 02:31 |
The references are:
Launder, "Heat and Mass Transport" in Turbulence, Chapter 6, Ed. Bradshaw, Springer, Berlin, (1978). Reynolds, "The prediction of turbulent Prandtl and Schmidt numbers", Int.J.Heat Mass Transfer, Vol.18, p1055, (1975). Hinze, "Transport of a scalar quantity in wall turbulence" in Turbulence, 2nd Edition, Chapter 7, McGraw Hill, (1975). |
August 27, 2002, 09:23 |
Sorry for the delay, but I now have the references. I will have a look and let you know how I get on. Thanks once again for your time. John
August 29, 2002, 11:04 |
I have now looked through the references - I had now idea the issue was so complicated! I have found a further reference you may be interested in:
The height dependence of the turbulent Schmidt number within the boundary layer, Koeltzsh 2000, from the journal of atmospheric environment (I think). Thanks once again for your time. John |
May 31, 2015, 22:36 |
yunhaifeiyang
Rep Power: 10 |
In Fluent, the default schmidt number is 0.85 for conventional fluid (air and water et al.), but for heavy metal (lead bismuth eutectic et al.), its schmidt number is larger than 1.0. So I want to set it 4.22 instead of 0.85. But I don't know how to do it? Use UDF? Please help me!
June 1, 2015, 05:04 |
#9 |
Cees Haringa
If you go to viscous to set the turbulence model, there is a column on the right with a number of constants. if you have species enabled, this will include the turbulent schmidt number as well. Best, Cees |
Display Modes | |
Low Reynolds number k-E Turbulent Model | Sohail | FLUENT | 19 | July 16, 2020 14:08 |
Problem with decomposePar tool | vinz | OpenFOAM Pre-Processing | 18 | January 26, 2011 02:17 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
Question on Schmidt number | ap | Main CFD Forum | 0 | March 26, 2008 18:58 |
Turbulent Cylinder Strouhal Number | Chetan Kadakia | FLUENT | 3 | October 10, 2002 03:31 |
