Visualisation problem pls help!
Old   June 13, 2008, 10:17
Default Visualisation problem pls help!
Juan
Hello, I am trying to simulate a toilet flush flow using fluent. I have managed to simulate the flush from 0 up to 15 seconds using VOF and everything seemed right. However I am having trouble visualizing the VOF for the post-process. I am simply trying to obtain a video showing the flow of the flush, however the fraction of VOF I use (0.5) doesn't show all the water flow. If I use a lower fraction, it shows a mixture of air and water. I only need a clear image to distinguish air with water. Could anyone help me with this issue?
The settings I have used are as follows.
3 phase VOF (water pressure, water interior volume and air interior volume), Implicit, Open channel flow, 0 Gauge pressure for air inlet and outlet, PISO and Body force weighted.
Thank you
Old   June 14, 2008, 02:08
Default Re: Visualisation problem pls help!
HSeldon
Hi, when you display the results, did you try to check the "clip to range" option? You could clip your visualization from 1 to 1 for example to only see the water. I hope I was clear. Good luck!
Old   June 17, 2008, 04:23
Juan
Thank you for your response, I have tried to clip the visualization from 1-1, however nothing appears at the display (except the grid geometry). I´ve tried contour display with VOF of the water phase and filled the cells, Is this the right configuration?
Thank you again
Old   July 8, 2012, 13:01
Blue's Avatar
Blue is on a distinguished road
Hey, I have similar problem now. In my simulation of water tank(inlet from upside and outlet from bottom) I dont find clear difference between water and air. It all mixes. Plz reply thnx
Blue is offline   Reply With Quote
VOF visualisation help. Juan FLUENT 1 June 16, 2008 07:36
Flow visualisation bouca FLUENT 1 March 16, 2001 15:45
Visualisation Noel Rycroft Main CFD Forum 3 October 22, 2000 06:42
Visualisation of baffles! Anders Jönson Siemens 1 August 9, 2000 01:31
FAST/Visualisation Chris Robinson Main CFD Forum 3 December 3, 1999 00:56
