fresh install - floating-point exception
Hi
I've just installed fluent 6.1, gambit 2.0.4 and exceed 6.2. Every time I run Gambit, immediately when it loads up it says a fatal error has occurred. It is not possible for gambit to continue from this point. Received exception: Floating-point exception Then refers to the GAMBIT.5456/trn which says: *** LISTING "default_id" FILES IN DIRECTORY: . default_id.lok Has anyone had any past experience with this problem and found a solution? Thanks |
