July 2, 2008, 22:02 |
operating pressure
I am trying to replicate my lab experiment that is flow over a heated flat plate at a high local reynolds number. In order to prevent pump cavitation I have to pressurize the loop to 25 PSI. When modeling this in Fluent I can set the operating pressure as such, but does that also modify the outlet pressure or do I need to set that as well from the default of zero guage?
thanks |
July 3, 2008, 04:47 |
Re: operating pressure
The outlet pressure will certainly affected by the operating pressure definition. I think no caviation will appear in Flent if you don't turn the caviation model on.
July 4, 2008, 03:52 |
however absolute pressure will go below the saturation pressure with no cav model. Using the cav model you may also see negative absolute pressure in Fluent.
Display Modes | |
operating pressure and operating density | phil | FLUENT | 5 | November 7, 2017 17:02 |
gauge pressure and operating pressure? | António Nery | FLUENT | 3 | December 14, 2016 06:54 |
OPERATING PRESSURE | manish | FLUENT | 6 | February 25, 2011 04:40 |
Operating Pressure | D Harvey | FLUENT | 0 | June 4, 2004 13:12 |
Operating Pressure | Nori | FLUENT | 1 | April 7, 2004 11:29 |
