July 3, 2008, 07:24 |
Heat transfer/ Temperature calculation
hi all,
I have to calculate the temperature distribution inside a clossed vessel(cylinder) with some Quartz glass rods inside the cyllinder. The cylinder consistes of water(99% water and 1% air). Quartz rods are operated at different temperatures(the end points are operated at different temp to that of the middle). Can anybody please let me know how can i sep up the case. And what should be the timestep size and howmany number of time step should i consider. Thanks in advance |
Calculation of heat transfer coefficients | uli_u | OpenFOAM Running, Solving & CFD | 16 | November 25, 2009 10:41 |
Calculation of Heat Transfer coefficient | sachin | CFX | 2 | February 16, 2009 02:24 |
Heat transfer coefficient calculation. | Jimmy | Siemens | 3 | February 19, 2008 16:53 |
Boiling heat transfer calculation | david | CFX | 0 | June 21, 2005 04:17 |
Turbulent heat transfer calculation | Frank Rubensdorffer | FLUENT | 2 | May 29, 2002 14:37 |
