July 3, 2008, 17:10 |
LES turbulence decaying in channel
Hi
I am running a channel flow using LES. My problem is that turbulence after developing for a bit starts to decay in channel. And after a while I see zero turbulence in my domain. What can I do under such circumstances to sustain the turbulence. Thank you for your answer. |
July 4, 2008, 12:55 |
Re: LES turbulence decaying in channel
give more details on what you simulating. maybe I can help
July 4, 2008, 13:32 |
Hi Renato
Thank you for your answer. I am using periodic boundary with pressure drop between inlet and outlet. I am using RANS solution as initial condition. Mesh is hexa unstructured with very low YPlus values, below 1. I have half a million cells in my grid. Courant number is 0.6 and the length of channel is 1.6m. Discretisation scheme is central difference. Thanks in advance for your help. |
July 4, 2008, 14:08 |
ok, but when you start with RANS you have some turbulence forming and when you change to LES it dissapear? is it?
Turbulence in channel become laminar | pankaj saha | Main CFD Forum | 1 | November 9, 2010 07:16 |
LES turbulence decaying in channel flow | cfdIsMad | Main CFD Forum | 6 | August 21, 2009 12:17 |
LES turbulence decaying in channel | cfdIsMad | Siemens | 2 | July 4, 2008 08:40 |
LES turbulence decaying in channel flow | cfdIsMad | CFX | 4 | July 4, 2008 06:29 |
Stabilizing turbulence equation in channel flow | Biga | Main CFD Forum | 5 | March 22, 2005 20:06 |
