July 7, 2008, 08:36 |
continuity convergence vof
hi all, currently i set up a case for a mold filling simulation using vof with piso velocity pressure coupling, presto pressure discretization, first-order in time and second order discretization in space,CICSAM for volume fraction with default under relaxations. i used quite fine tetra mesh with a max skew.<0.8 and then convert all domain to polyhedral.At the first time step, except the continuity,velocity and energy are converged. What may the problem, please help regards ali
continuity convergence | cristion | FLUENT | 12 | May 6, 2014 04:51 |
Convergence of Continuity | Dodi | FLUENT | 0 | February 28, 2009 16:03 |
Continuity eq convergence problem | carno | FLUENT | 4 | February 8, 2008 04:04 |
Continuity Convergence | Marc | FLUENT | 0 | November 27, 2007 10:57 |
continuity convergence? | CFDnewbie | FLUENT | 1 | August 4, 2005 11:35 |
