July 11, 2008, 03:31 |
IMPORT GEOMETRY FROM SOLID EDGE
what is the procedure to import a 2D geometry from solid edge to gambit 2.2.30?
July 11, 2008, 04:03 |
Re: IMPORT GEOMETRY FROM SOLID EDGE
I don't know if you can export your 2d geometry in STEP File. If yes, import the STEP file into gambit. I already did it from ProE
Solid Edge to Star-CCM+ | James | Siemens | 3 | November 1, 2006 08:02 |
Solid Edge | Micaela Olivetti | Main CFD Forum | 2 | July 17, 2006 02:30 |
Solid Edge and CFD | Shaper | Main CFD Forum | 1 | February 3, 2006 11:10 |
solid edge problem....can you help? | cindy | Main CFD Forum | 3 | April 5, 2004 13:43 |
starcd and solid edge | salvatore | Siemens | 0 | June 9, 2001 18:35 |
