Fidap to Fluent
Old   July 10, 2008, 13:40
Default Fidap to Fluent
Ravi
Hi guys
Its been a while since I posted on this forum. I have returned to soing some CFD related research after almost an year now. And this is where I need some help from you guys.
1. I have heard that Fluent has discontinued supporting fidap. And for this reason, my research lab has purchased new licenses for fluent, and we are soon to begin the process of migrating from fidap to fluent.
2. Apart from knowing the basic difference between the two (fidap being FE based and fluent being volume-difference based), I have no idea about fluent. I have never worked with it before and looks like I have to use it for atleast 3 years to come.
My question is, are there any users here that have had the same issue of migrating from Fidap to Fluent? What are your general experiences, and what do I need to know to use fluent since this will be the first time I would use it.
Its pretty frustrating since I used fidap extensively for my MS thesis, and when I come back to the same lab after an year, I am still a novice in using the CFD software because it Fluent now instead of Fidap. Any tips on where to get started ith fluent?
Ravi
Old   July 10, 2008, 14:14
Default Re: Fidap to Fluent
mettler
In my opinion, the best way to get started with Fluent is to work thru the tutorials that are supplied. You can usually find a tutorial that will resemble the research you are trying to do. That is how I learned Fluent.
Old   July 10, 2008, 14:18
N.Veiga
Try the fluent tutorial suggest by the cornell university. http://courses.cit.cornell.edu/fluent/
good luck
Old   July 10, 2008, 14:31
Ravi
Thanks Mettler and Veiga. Although, the tutorials only focus on GUIs. I need to run fidap on a linux based command line interface.
Ravi
FIDAP vs. FLUENT Aireen FLUENT 4 August 9, 2006 12:27
user guide of fluent fidap ztdep FLUENT 1 April 4, 2006 15:29
Fluent or Fidap? Ravi FLUENT 1 January 25, 2006 03:35
FLUENT VS FIDAP : GEOMESH VS FI-GEN yogi Main CFD Forum 4 October 4, 1999 10:23
Fluent vs. Fidap Lisa Eastep Main CFD Forum 1 July 16, 1999 01:13
