July 9, 2008, 20:33 |
convection heat transfer
Hi all! i have problem in convective heat transfer.my cylinder wall tempreture is at 25 degree and fluid inside the cylinder is at 5 degree.this is unsteady state problem.i plot the graph for Average tempreture of the fluid Vs Time in the fluent.Now i need to plot the same graph by changing the different value of the thermal conductivity of the fluid. Can anyone help me in this problem??
July 13, 2008, 13:25 |
Re: convection heat transfer
You can write a journal that change conductivity then iterate to solution then write (appends) the average temperature in a file. You can repeat these 3 steps in your journal as many time as you want just by copy-past the lines (just do a long repetitive journal) but with new conductivity.
In order to write the journal, I suggest you to start doing the 3 steps using the TUI in order to find out what the commands should be. Once you can do it with the TUI, it's exactly the sames commands for the journal. |
July 13, 2008, 13:32 |
You want to have many Temperature vs time profil? (with different conductivity)? In that case, I think it's best to write each profil in a different file (one file for each profil). Just use a diffent name for the file in the journal for each repetition of the 3 steps.
July 13, 2008, 14:57 |
hi micael! thanks for ur reply..u r taking about which journal..can u specify the procedure in detail plz....thanks again for ur help
Display Modes | |
Forced convection heat transfer in heat sink | Sidy | FLUENT | 1 | October 18, 2008 04:27 |
heat transfer with natural convection. | Juan Catelén | CFX | 3 | January 10, 2007 18:49 |
heat transfer coefficient - forced convection | Tes | Siemens | 2 | April 16, 2005 19:14 |
heat transfer coefficient - forced convection | Tes | Main CFD Forum | 0 | March 26, 2005 09:17 |
Natural convection heat transfer | Tamm | FLUENT | 1 | January 5, 2005 02:38 |
