Meshing pipe intersection in an exhaust system |
July 9, 2008, 02:58 |
Hi all, i'm trying to mesh a volume composed by two pipes intersecting with an angle of 21 degrees between their axes. I'm doing the GAMBIT tutorial, in several examples Cooper scheme is used, at this point i'm in bubt if the effort of dividing the volume in order to use Cooper to achieve some advantage in calculation or use a Tet\Hybrid scheme. For the acuueracy of the results i need to apply boundary layers, i have tryed to use Cooper but there i a proble with the faces to project along because the one where the two pipes intersect is seen as a hole, i'm tyring to solve with a virtual surface but this on is not well shaped. Any advice with a better scheme or a smart volume subdivision is welcome.
Thanks in advance. |
July 9, 2008, 20:02 |
Re: Meshing pipe intersection in an exhaust system
You can mesh this with cooper if you split the volumes correctly. Its is difficult to descibe how to do this here!
An alternative is to use 3D face boundary layers and mesh with Tet mesher. |
July 10, 2008, 02:50 |
Thank you for the answer,i have tryed to split the volume by means of a surface at the intersection that would follow the generatrix of the main cylinder, but instead GAMBIT creates a virtual surface that partially follow the cylinder generatrix and partially the intersection curve generatrix, so it's shape is strange and i can't project along, i'm looking to understand how to use the external face of the main cylinder as Host. Even if i success in that i don't know if i should use Cooper on the smallest cilinder because it has a flat end and another with a sharp edge due to the 21 degrees angle. Btw is Cooper scheme so important to avoid convergence problem instead of using Tet/Hybryd? About the 3D boundary layers, to use them i was forced to change a default variable because one of the end faces wasn't planar, i don't remeber exactly which option.
July 14, 2008, 11:54 |
Ok i've divided the volume in 2 parts. But due to the shape of the pipe with 21 degrees i get an high skewness with Copper scheme, is ok if i use 2 different schemes for the 2 parts?
July 17, 2008, 04:33 |
Hi all again, i have solved my meshing prolems by using a 3D boundary layer on the wall surfaces and filing the volume with a Tetrahedral\TGrid scheme. Now i have completed a short steady simulation to obtain the field in which the droplets will be injected. Even with a very corse grid (only 12300 cells) i got the expected results for the velocity field, but instead the temperature field (both Static and Total) are the same in magnitude and contours and almost constant everywhere even if the velocity varies greatly, i got an inlet boumdary condition with 0.054 Kg/sec and 337 celsius at the outlet i have used Outflow maybe Pressure would be more appropriate?I have supposed no wall heat flux due to lack of data. Any ideas why the temperature field is like that? Thanks in advance.
Display Modes | |
Exhaust System | Chirag | CFX | 1 | July 10, 2008 21:41 |
Gambit - meshing 2 pipes' intersection | mrt | FLUENT | 0 | July 10, 2007 07:58 |
meshing at a pipe intersection | cyn | FLUENT | 0 | December 20, 2006 02:16 |
after-treatment exhaust pipe and catalyst systems | Gunter | Siemens | 0 | December 10, 2006 14:15 |
3d-pipe intersection in same plane | Pravir Kumar Rai | FLUENT | 3 | February 26, 2002 13:56 |
