September 12, 2008, 16:38 |
SOS!!
dear everybody!!
how can i plot flow variables through pathlines? thanks |
September 15, 2008, 22:01 |
Re: SOS!!
Can you give us an example??
You can display the pathlines colored by a flow variable. In the Display> Pathlines panel, go the droplist under color by and select the variable that you want. Other option in the same panel is selecting the XY Plot checkbox on the left side, and define the X Axis Function as Path length, and Y Axis Function as the flow variable that you want. Cheers, Javier |
