January 10, 2012, 05:47 |
Solving 3 phase flow
Hi all !!!
I am new to fluent and I have to solve a 3 phase flow problem(2 immiscible liquid phases and a vapor phase) using fluent, the 3rd phase being water being injected into the system. I am using mixture as multiphase model. But, I'm not able to allocate the water as my 3rd phase under phases. Also, in injections, i'm not able to select the droplet option, so i'm using inert-material under injections and selecting water. Kindly suggest how water(the material of injection) can be considered as the 3rd phase. Because in my case water injected also evaporates. Thank you for your time. |
3 phase, evaporate, injections |
transsonic nozzle with rhoSimpleFoam | Unseen | OpenFOAM Running, Solving & CFD | 8 | July 1, 2022 06:54 |
Velocity blows up suddenly after 30,000+ iterations | lordvon | OpenFOAM Running, Solving & CFD | 15 | October 19, 2015 13:52 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
Low Mach number Compressible jet flow using LES | ankgupta8um | OpenFOAM Running, Solving & CFD | 7 | January 15, 2011 13:38 |
Problems with simulating TurbFOAM | barath.ezhilan | OpenFOAM | 13 | July 16, 2009 05:55 |
