September 24, 2008, 06:08 |
fluent installation error
Hi all,
I would appreciate to get help form people who konw how to set the environment variable in linux I am getting the following error Error: directory /usr/local/Fluent.Inc/fluent6.3.26 does not contain a valid arch. Set the environment variable FLUENT_ARCH and try again. I am using a 64 bit machine hp laptop and the os is ubuntu 8,0 I request you to help me out in fixing this |
September 25, 2008, 20:31 |
Re: fluent installation error
may yo must to set the valid architecture for your instalation--try with: (in terminal, move to /usr/local/Fluent.Inc/bin/) $ FLUENT_ARCH=lnamd64 fluent
good luck! |
September 25, 2008, 21:58 |
Hi Thanks for the reply. I have tried the option but it did not work.
I am using linux 32 bit version in 64 bit machine and os do u think it will work I am getting the same error I did as u told went to the /usr/local/Fluent.Inc/bin floder and wrote this command FLUENT_ARCH =lnamd64 and export FLUENT_ARCH but after that also it gives me the same error /usr/local/Fluent.Inc/fluent6.3.26/bin/fluent -r6.3.26 Error: directory /usr/local/Fluent.Inc/fluent6.3.26 does not contain a valid arch. Set the environment variable FLUENT_ARCH and try again. thanks for any sort of help am using ubuntu latest version with kde 3.5on intel with core 2 duo 2.26 ghz 8400 processor |
Display Modes | |
OF15dev installation error | velan | OpenFOAM Installation | 11 | February 13, 2009 10:23 |
Installation error | sukratu | OpenFOAM Installation | 6 | September 16, 2007 23:46 |
Error after installation.. | Nari | Siemens | 5 | June 28, 2007 15:02 |
Installation Error | rafal | OpenFOAM Installation | 3 | February 2, 2006 12:43 |
Fluent 6.2.16 installation with Error EOF | tuks | FLUENT | 3 | July 13, 2005 14:20 |
