pb with batch mode
Old   October 21, 2008, 12:42
Default pb with batch mode
philippe
hi, i'd like to use the batch mode but i have some problems. I want to make calculus for different viscosities of my fluid. I use: 1) fluent 3ddp -i test1.jou
or 2) fluent 3d -g <test1.jou>& testmoi &
and my test1.jou is: /file/read-case test1.cas /solve/iterate 30 /file/write-case test11.cas yes
/file/read-case test2.cas /solve/iterate 30 /file/write-case test22.cas yes
/exit yes
but when i use it it doesn't work...
someone can help me please
tkx
Old   October 21, 2008, 14:04
Default Re: pb with batch mode
Veera Gutti
You need to initialize your solution after you read your case file in batch mode.
use /solve/initialize/initialize-flow
to initialize the solution and then use commands to perform iterations.
Old   October 21, 2008, 17:39
philippe
tkx i'll check that tomorrow and which one of these solutions should i take?
or 2) fluent 3d -g & testmoi &
tkx again
Batch Mode Titiksh Patel FLUENT 13 February 1, 2010 14:48
batch mode Peter Schaller FloEFD, FloWorks & FloTHERM 2 October 6, 2008 03:18
Batch mode in WB. cfdguy CFX 1 June 24, 2008 06:49
Pre in batch mode Kuts CFX 7 August 17, 2007 05:10
DPM in Batch Mode MM FLUENT 0 December 15, 2006 13:17
