Error Message after Face Check
Old   October 21, 2008, 02:57
Default Error Message after Face Check
J, KRICK
Hallo,
after importing a part from Solidworks by the .STEP format, I performed a Face Check on all faces:
Cmd> face check topology geometry
GAMBIT's answer was the following:
ERROR: ACIS error 4208 : surface is not G1 EROOR: Problematic geometry reported for the face face.128
I searched the web for a similar error message, but couldn't find anything.
My question is: What does this error message mean? What can I do to repair the face face.128?
Thanks,
Julian
Old   October 21, 2008, 04:00
Default Re: Error Message after Face Check
mAx
try to delete the volume without lower topology (eg: faces), and then delete face.128. Rebuild face.128, with wireframe (from edges) and rebuild the volume with wirefram (from faces) it could work
Fluent Grid Check: Left-handed & right handed face Haider FLUENT 3 March 22, 2009 23:01
error message"reversed flow in face on otflow" DOCTEUR FLUENT 3 May 27, 2006 05:56
Grid Check Error sak FLUENT 4 August 26, 2005 04:10
help! grid check error Gary Holland FLUENT 9 April 25, 2005 13:37
Grid Check error Taher FLUENT 3 August 30, 2002 09:55
