June 24, 2013, 07:45 |
Extracting result from fluent xy plot
Hi.... I am having difficulty extracting result from the wall of my 3d cylindrical model, where I want to find the x-y plot of static pressure vs distance on the wall surface.... the results are not clear when I select wall option to plot the graph because of 3d nature of the model... can someone please explain how to obtain the result from wall of cylindrical model along a line...
P.S. I tried making a line coinciding with the wall surface but due to the dynamic nature of the wall it could only capture 2-3 points.... |
June 25, 2013, 06:38 |
OJ
Rep Power: 20 |
What do you mean by dynamic nature of the wall?
How about this, open the results in CFD Post and create a polyline as an intersection of a plane and wall. And then plot pressure on it? OJ |
June 25, 2013, 08:45 |
by dynamic nature I mean that is it is moving in a sinusoidal pattern resembling a model in vibration
May 14, 2014, 19:22 |
NSW
Hi Nitman,
Were you able to find a solution to your problem? I'm faced with the same situation and it would be great if you could share your experience. Thank you! |
Different result in CFX and fluent for mass trans.? is segregated better? | ftab | CFX | 7 | September 27, 2012 07:57 |
Result comparision of CFX and fluent | sunxihui | CFX | 1 | September 24, 2012 20:42 |
plot x,y on fluent | Ricky | FLUENT | 1 | May 27, 2009 06:18 |
How to plot the radius of a droplet's fall with Fluent | baechtel | FLUENT | 1 | May 1, 2009 04:51 |
Comparing Fluent Time dependent result with Patran | venigall | FLUENT | 0 | January 13, 2007 19:30 |
